Alex Sutherland
Recently it appeared my AC68U had stopped working, I could still connect via WiFi but I couldn't ping the LAN address via the RJ45 connection. I tried resetting to factory defaults but this didn't work.
The router was a out of warranty so I decided to purchase a AC88U router as a replacement.
After transferring the config using the NVRAM Save/Restore Utility everything worked fine... for about 2 days.
This router now the same problem are the first one?? I think its very unlikely both routers would develop the same problem so I closer look.
I reset the AC88U back to factory defaults and reapplied the latest firmware reapplied the settings and the device came back to life?? I tried the same process on the AC68U device and now it also is working again.
Can someone advise whats going on and suggest a way to prevent it re-occuring?
