azazel1024
I originally got a TP-Link web smart switch, 16 port (SG-2216) when it was on deep sale for $110 or so. Its worked great, I love it, it looks sexy sitting over my server, ad nauseum.
The issue I have is as I've been wiring my house I've realized that 16 ports is not going to cut it. Currently I have 13 ports filled and at a minimum I have 4 more, 1 for my daughters bedroom, 1 more in my playroom/family room (so it can do double duty as a home office in a few years when my kids are older), 1 in some built in bookcases for a networked stereo and 1 GBIC+fiber taking up a port to run out to a shed/workshop in a couple of years.
That doesn't include that in about 2-3 years I am tearing down my garage and building a nicer garage with master suite over it and have plans to blow out the back for a big living room and expanded kitchen later. All of that will likely need at least 1 more port in the garage, master bedroom and new living room.
So, not enough ports, eventually. I am fine for a couple of years, but soon I'll be over my limit. I have an 8 port Trendnet dumb switch I can hook in to expand my port capacity which is fine.
However, ideally I'd like to increase the switching capacity. I currently run two ports for my server and for my desktop. Looking at future needs and uses of spaces, I could see possibly hitting a limit on switching capacity between the switches under some circumstances even with careful management of which ports are connected to which switches.
So, bonding/SMB3.0+ question for you.
Under Windows 8+ with SMB3, you get SMB multichannel, which is awesome. Its what I use between my server and my desktop to get ~230MB/sec speeds between my RAID arrays with a couple of Intel CT GbE NICs in each machine (onboard LAN disabled on both machines). With SMB3 and/or in general with dump switches, can I just connect two ports to two ports between the switches? Or will this setup a loop back event?
To avoid a possible loop back, I assume I'd need to do port bonding? Which I'd need a managed switch that supported that (like my SG-2216 does)? Yes?
Just trying to get an idea for the future what kind of switches I'd need to look at. In the short term when I go over the port limit, I'll just use the 8 port unmanaged switch and 1-1 connection between switches, though if it'd support 2-2, sure, why not. With 2-2/bonded, I doubt I'll have enough ports very long term with a setup like that (only 20 free, and I am thinking I'll be using 22-24 in the end. Maybe just get rid of the sg2216 and go with a 24 port model? I'll want to mix in 10GbE some day. Hmmm).
Anyway, thanks!
Anyway, thanks!
