Expanding the ReadyNAS Duo
ReD-BaRoN
I'm thinking I want a 2 drive NAS in order to pop in a second drive when the first drive becomes full.
I just want to make sure I understand the expansion situation with the ReadyNAS Duo. I can't configure the Duo as JBOD, so I won't be able to just pop in 2nd disk to expand, correct? If I want to have two disks in the Duo which would actually equal the total storage of the two disks (i.e. 2 x 1.5TB = 3TB), that would have to be RAID 0 and I'd have to do that at initial install, to leverage the RAID 0 across the two drives, correct?
Am I missing something here? Given what I believe the facts are above, it doesn't seem the Duo will fit my needs.
Thanks!
I'm presuming that wouldn't look like a single disk anymore and would then be represented to the network as two different disks. The method described also soulds like it could potentially lose data (deleting the RAID 1 volume and converting to RAID 0).
Can the QNAP TS-219 or the Synology DS209 do what I'm looking for?
Tim, do you have plans to review the TS-219?
What does online RAID expansion mean?
You would set the system to FlexRAID mode when you set it up. So no data loss is involved.
The QNAP TS-219 manual says it supports RAID migration from single drive to RAID 1. JBOD volumes are also supported. But there is no mention of other options for adding a second drive. I need to ask QNAP. I'll also ask Synology.
No. TS-239 Pro is more likely.
It means the ability to swap out one disk of a RAID array at a time, let the array rebuild, then repeat until all drives have been replaced with larger drives in order to expand storage capacity.
jbod will also lose data.. the data of the disk failing. if you configure it as two raid0 volumes, you will have 2 logical drives, which (as you guessed) dont show up as a single drive. if 1 drive fails, the other one will be fine.
you can also configure it as a true raid0 which will make it appear as a single big drive, but will in turn cost you all your data if one drive fails.
This is interesting.
I don't see a single disk NAS being sufficient given the largest HD size being 2TB at the moment, and those 2TB HDs not on many NAS approved lists yet.
So I see at least the need for a 2 disk NAS, but I wasn't looking to populate both disks at the same time. Reasoning is that 2TB will hold me for a while, and when I need more space, I would just pop another disk in. At that time disk sizes will also be larger. Therefore RAID 0 is out, but JBOD should support this correct? I.e. I start with a 2TB drive, add a 3TB drive, and now I have a single network share of 5TB.
Do most people with 2 drive NASs buy both disks to populate it at the same time and run RAID 0?
Thanks!
