222fbj
I have a TPlink TL-WR1043ND on order... it has 3 antennas/ports. I will be moving the antennas 1meter away from the router so I can keep the router/wiring hidden, and put the antenna in a location (above my desk)that I hope will help solve some improve some weak signal spots.
What antenna(s) do I need? The TPLink TL-ANT2403N "3dbi" seems like a logical choice. Or, how about the ANT2408C "8dbi"?
btw - are '3 antenna' routers designed for 'one per (xyx) axis' ?
thanks
thanks
