Extremely slow PPTP download rate
AsusMerlinNoob
Heya, I've been banging my head against every wall to realize what is wrong but I couldn't solve it so I made an account here to see if I can get any expert help.
Here's my issue:
I have an ASUS RT-AC88U router running the latest merlin firmware and my own pptp vpn running on it off of a Centos 7 server.
My usual download speeds without the VPN are around 100-150 Mbps but when running the VPN, my download speeds barely break 1 Mbps...
Upload speeds don't change much, the drop is kind of expected.
I've also tried running the same PPTP server on a D-Link with dd wrt and it runs with speeds that you would expect.
I understand that PPTP is obsolete at this point but I need it for a specific use.
Any advice would be appreciated, thank you.
Edit: Happy new year!
I can't really follow what you said. Where/what is the VPN client, and where/what is the VPN server. How does the Centos server fit into this, is it running a VPN client or server?
Thanks for your reply.
The server is a Centos 7 machine running the pptpd service and the client is my RT-AC88U on the latest merlin.
So the RT-AC88U is at location A, and there is another router at location B that is forwarding the PPTP ports to the Centos server on its LAN. Correct?
Technically yes, the RT-AC88U is sitting in my home and clients in my home are running off of it and the Centos 7 server is sitting on a cloud machine running the PPTP server.
Can you try a PPTP client simply running on a PC. If you experience the same issue it would indicate that it's a server-side problem.
Sorry, no idea then. But I don't use PPTP myself.
BTW On the Asus there are two places to configure "PPTP", WAN > Internet Connection and VPN > VPN Client. I don't know what the differences are.
WAN is for ISPs that require PPTP to connect to the Internet (mostly a few Russian ISPs), while VPN page is for connecting to a server through your existing Internet connection.
