Fiber - QoS - AX86
Xrsenal
Hey everyone!
someone lost me the best possible QoS for Verizon Fios (600/950) are my speeds: for the most part, I don’t lag but here and there (even on my own host) I lag or the game feels off. The gaming port on the router feels weird and feels better using the other lan ports.
so I’m thinking maybe it’s bufferbloat!
idk how to configure cake and the overhead lol
is flex QoS better for gaming??
What model router and firmware.
Could be.
Use ethernet with vlan. Down and up rates set here should be 85%-95% of actual performance.
I believe Flex has more configuration options. It's a use case scenario. Whatever works better for you. Try Cake and then if you have trouble try Flex. Oh and one more thing your Fios feed that fast, you shouldn't need QOS.
I don’t think I suffer from bloat ; but I think my packets within my network are being dropped at times ; small packet loss
I tried the Gaming port on my asus ax86 but it felt super weird and delayed
Could be.
Will anything help with gaming packets? Hi
High latency to servers you connect to, perhaps. You can't fix this with QoS.
Peer 2 peer My friend; even when I host at times … I was using the 2.5 port w my ps5 (1gbps card)
could that be why I was having issues?
even though asus auto read it as 1gbps as connection status
Peer 2 peer
P2P doesn't guarantee you low latency. You definitely don't have bufferbloat when gaming on a 950/600 ISP. Your only QoS option is Adaptive QoS with Flex as an option to experiment with. Try it and see if it improves anything. Cake QoS will limit your speeds to about 320Mbps - no hardware acceleration.
hmmm I can experiment with flex but idk how to upload it to Merlin for my asus ax86
Also, is it bad that I use the 2.5 G port? My ps5 is on 1gbps. Could that cause any issue at all?
It installs through AMTM - Asuswrt-Merlin Terminal Menu. More information here - https://diversion.ch/amtm.html
The 2.5Gb port is on a separate controller. This what I know about it as hardware. Your 1Gbps limited PS5 has no advantage on this port. Game consoles need speed only when downloading games, but not during game play.
why default?
Also would that give my the best advantage for gaming (2.5 port) or would the gaming port or a regular lan port?
In your own opinion, would using any type of QoS be helpful? (I’ve got 19 devices total)
connection speed is 600/950 Fios
Could be.
