im having an issue with a USB Flash Drive and my router for some reason its changing my file format to ext2 from ext3 and showing the error below
also i have just formatted it back to ext3 and iv ended up with it back to this
ASUS: Superblock has an invalid journal (inode 8).
CLEARED.
*** ext3 journal has been deleted - filesystem is now ext2 only ***
ASUS was not cleanly unmounted, check forced.
ASUS: Inode 8 has EXTENTS_FL flag set on filesystem without extents support.
ASUS: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
I'm sure this might be simple to most experienced users but i haven't a clue what i need to do to fix this issue.
im on merlin's latest firmware too and its a 64gb usb 3.0 connected to the USB 3.0 socket
and just to add i have used a 32gb usb for over a year now without an issue so i dont know if thats a factor with the size
CLEARED.
