Filename Length restrictions?
sharkytm
Hello folks,
I've got a Promise NS4300N, and I'm running into trouble copying some files to it. The file names are extremely long, 124 characters.
For example
southtsp.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.999.012.ped
It will copy over a few, then hits one of these, and just freezes. The file size is only 15kB, so its not a size issue.
Whats the length restriction on these devices?
Thanks.
I assume you're not able to change the names? According to Google/Wikipedia that NAS uses a (modified) ext3 file system, which has a 255 character limit on filenames. Are these files on the root of the drive or inside a subdirectory? If it's the latter, I would try copying it to the root, see if you could get around whatever limit you are hitting.
samba has some a lot of config around file names to handle different operating systems. Not sure you have access to any of that on your device
z
I'd love to, but if it can't be in a folder, its not worth having the NAS for these files. These are data files from surveys, and have to be in folders with dates, names, etc.
