files to restore dhcp reservations
jata
Hi all,
Planning to do a manual reset of my router RT-AX86S after upgrading from 386.7 to 388.1 but wanted to restore the manual dhcp reservations by restoring the following file /jffs/nvram/dhcp_staticlist
Just wanted to check if this is the only file I need to copy - i think I have seen a post by @Tech9 listing a couple of other files but I can't find the post...
Thanks in advance and big thanks to @RMerlin and the community for all the great work / advice!
From /jffs/nvram save:
dhcp_staticlist
custom_clientlist
custom_usericon
After reset enable Manual Assignment in DHCP Server, copy the files back, reboot.
You have back DHCP reservations and your client names and icons you have assigned.
