Finding Where "Traffic Analyzer - Statistic" On/Off Is Stored
Kevin K
I'm looking at the source to TrafficAnalyzer_Statistic.asp, trying to figure out where the On/Off flag is stored. In the code, I see:
   $('#traffic_analysis_enable').iphoneSwitch('<% nvram_get("bwdpi_db_enable"); %>',
    function(){
        switch_control(1);
    function(){
        switch_control(0);
That sorta looks like bwdpi_db_enable in nvram controls whether "Traffic Analyzer - Statistic" is turned on or off. Yet when I toggle the switch, running `nvram get bwdpi_db_enable` just keeps returning 1.
I'm interested in two questions:
  • Where *does* "Traffic Analyzer - Statistic" on/off get saved?
  • I'm going to be doing lots of poking around to find where various config options get saved, because I want to put as much setup into ansible as I can. What's wrong with my method for researching where "Traffic Analyzer - Statistic" is saved (so I can apply that refined method for other config items)?
That merely enables/disable apps analysis. The global traffic monitoring itself can't be enabled/disabled.
