Firefox and NoScript issues
GK59
I've begun to notice recently that while logging into the GUI (v384.6 FW) I'm experiencing hangups (java script delays) within NoScript while enabled, this did not pose any issues with earlier FW versions, has something changed either with the FW or perhaps FF itself? I simply disable it while I adjust settings, then re-enable it afterwards but just the same would like to know what this problem is attributed to, thanks.
The whole webui is highly Javascript-driven, it cannot be used without JS.
Whitelist your WebUI domain in NoScript. Been using it for a couple of years and no problems accessing the WebUI settings here.
