Firewall - Allow specific IP Addresses to port.
TomT
Hi
I'm running Firmware:376.45 (Merlin build) on my AC 68U
I'd like to block all IP Addresses to port 21 except 2 - 3 IP Addresses I allow.
Is that possible ?
if it is I'd then look to do the same to other ports.
Can't be done through the webui, has to manually be done with iptables.
Thanks for the reply.
Can anyone point me in the right direction.. On how to do this.
it is not very difficult, here for example my configaration of an SSH Port only reachable from specific IP:
iptables -t nat -I VSERVER <consecutive number> -p tcp -m tcp -s <ip-Adress> --dport <alternate-port> -j DNAT --to <server-ip in network>:<listen port>
e.g.:
iptables -t nat -I VSERVER 2 -p tcp -m tcp -s 1.2.3.4 --dport 2223 -j DNAT --to 192.168.1.2:22
this can be put into /jffs/scripts/nat-start
You can also find information about this here.
If you need more help, you're welcome
regards Boy1979
