Firewall logging question.
soehest
I am experimenting a bit with remote syslog and firewall logging and stumbled across this:
Mar 17 02:02:14 server kernel: DROP  <4>DROP IN=eth0 OUT= MAC=08:60:6f:21:b6:f0:68:ef:bd:85:a6:d9:08:00 <1>SRC=xxx.xxx.xxx.xxx DST=yyy.yyy.yyy.yyy <1>LEN=44 TOS=0x00 PREC=0x00 TTL=39 ID=808 PROTO=TCP <1>SPT=57233 DPT=1234 SEQ=2861804318 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4)
Mar 17 02:02:15 server kernel: DROP  <4>DROP IN=eth0 OUT= MAC=08:60:6f:21:b6:f0:68:ef:bd:85:a6:d9:08:00 <1>SRC=xxx.xxx.xxx.xxx DST=yyy.yyy.yyy.yyy <1>LEN=44 TOS=0x00 PREC=0x00 TTL=39 ID=34783 PROTO=TCP <1>SPT=57234 DPT=1234 SEQ=2861738783 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4
Drop is generated by issuing nmap -Pn -sS yyy.yyy.yyy.yyy -p 1234 at xxx.xxx.xxx.xxx. What I find odd is that it will log two times even with only a single scan. I have not experienced this with other types of routers/firewall where it will only log 1 line. Is this normal behavior?
Can you increase the verbosity of nmap and see exactly what packets it is sending?
That looks like two different packets with two different source ports and sequence numbers. It isn't logging a duplicate. It's logging what it is seeing twice...at least from what I can tell by what you provided.
Brilliant idea :-)
Having tried nmap with options: nmap -v8 --packet-trace -Pn -sS yyy.yyy.yyy.yyy 1234 I can see you are both correct. There are actually two packets sent. Think the culprit may be in that my previous solution used --limit 1/m --limit-burst 1, which would explain why I only was seeing one packet. Thanks for the idea of increasing verbosity :-)
Another question but related:
What are the <4> and <1> which is appended. My firewall log parser does not like them so I have to remove them which is not a big deal but a bit annoying. Especially when i do not know what those values in <> are?
Regards
