firewall rule for disabling guest intranet rt-n16
mohan_kr
I have RT-N16, running 354 Asus-Merlin (experimental)..I am wondering how to disable intranet access for the guest wireless. The option is not there in the RT-N16 version of the f/w. Can someone post the firewall iptables commands to disable guest wireless to the intranet.
You might need to do a factory default reset, especially if you came from the old blue UI (FW 1.xx).
