firewall start script problem / transmission port closed after every reboot
Nilugeator
Hi all,
I use an AC86U, firmware 384.13, with openvpn and transmission client.
My goal is to use only VPN for transmission.
For that, transmission is running on my router, and I binded it into 192.168.2.30
I set a policy based routing (strict) for 192.168.2.30 going through VPN
I had to forward port on my VPN provider, folowing my airvpn provider tutorial:
https://airvpn.org/faq/port_forwarding/
and
https://airvpn.org/forums/topic/9270-how-to-forward-ports-in-dd-wrt-tomato-with-iptables/
So basicaly I forwarded 26740 port on airvpn web GUI and I put this into my firewall- start script :
#!/bin/sh
iptables -I FORWARD -i tun11 -p udp -d 192.168.2.30 --dport 26740 -j ACCEPT
iptables -I FORWARD -i tun11 -p tcp -d 192.168.2.30 --dport 26740 -j ACCEPT
iptables -t nat -I PREROUTING -i tun11 -p tcp --dport 26740 -j DNAT --to-destination 192.168.2.30
iptables -t nat -I PREROUTING -i tun11 -p udp --dport 26740 -j DNAT --to-destination 192.168.2.30
And of course I made this script executable, with putty i send a :
chmod a+rx /jffs/scripts/firewall-start
Nevertheless, my problem is that after every reboot of my router, my 26740 port is definitively closed (tested with transmission port checking or canyouseeme)
So every time, I had to set again with putty :
And then port is opened again
Maybe firewall start script wont launch at startup? why and how to know that?
Maybe firewall start script launch at startup but something after it close my 26740 port? Why and how to know it?
Thank you very much for any help/idea about that
Try: dos2unix /jffs/scripts/firewall-start
and test again. Remove CR at end of line in firewall-start
