Joel Teixeira
Hey there,
I'm a little confused regarding port forwarding on my ASUS AC3200. I disabled uPnP since it seems to be related with some security concerns and mapped all ports manually. My main doubt is, do I need to use the firewall-start script if the rule is already on the "WAN - Virtual Server / Port Forwarding"?
If I create, for instance, a rule like:
Do I still need to open the ports on firewall-start with:
Or/And I should redirect using the firewall-star as well (not sure the syntax below is correct):
Is there any preferred method? When I create a redirect on Web UI it automatically open/forwards the port without needing to tweak with the script? Or the script is prefered and I shoud forget about the web UI when it comes to port forwaring?
Thanks a lot!
Thanks a lot!
