Firmware Version:384.11_2 Clear DNS over TLS not working?
jsmiddleton4
I tried DNS over TLS and this morning disabled it. I can't connect if turned off. It looks like the DNS alternative server information isn't clearing from the table/setting?
How do I go back to not using DNS-TLS stuff once I test it?
Can you post the syslog when you disable it and hit apply? Looking for dnsmasq log entries.
Glad to. Since I'm fooling around with stuff and have added static DNS servers like Google, OpenDNS, for both IPV4 and IPV6 my log is pretty long. What I see in the time stamp for when I was fooling around the DNS over TLS is a bunch of entries, like a lot of them, that say insecure. Is that what you're looking for?
Rows of this. Given I didn't give it any upstream DNS to "serve" they make sense. There wasn't any upstream DNS server. Not a big deal but seems like if you turn the option for privacy upstream server to "None", maybe a popup to say turn off DNSSEC or turn it off automatically? Although if you're messing with it probably should already know to turn it off.
Mostly my bad tackling a learning curve.
Jun 2 06:47:00 dnsmasq[2566]: Insecure DS reply received for com, could be bad domain configuration or lack of DNSSEC support from upstream DNS servers
Jun 2 06:47:01 rc_service: udhcpc 4190:notify_rc start_dhcp6c
Most likely your ISP DNS servers do not support DNSSEC. Try Cloudflare, 1.1.1.1 and 1.0.0.1 with DoT and DNSSEC enabled. This combo seems to work best for me.
Yes I understand.
It is interesting that even though I hit the minus key for removing the entries and Apply it appears the entries are not actually removed from the internal table.
