First time asuswrt user
du3z
Hi guys
first time using an asus ac87u router, just flashed the latest 3.0.0.4_376.48_1 and rebooted. Told me to use wireless to connect to the router but..how do I find out what the router IP is?? Was previously set to 192.168.1.254 as it is a set to AP (2nd router) :eek:
Nevermind, I found a trick on googling,
arp -a
(ipconfig doesn't work since it lists my default router/gateway :p)
That message is usually due to the browser having an inconsistent page in it's cache. If you clear the browser cache it should work.
Also, where you can, you should disable offline caching and and any browser/system addons (things like password managers, adblockers) for the router web pages.
If you are using firefox, to disable the caching....
Tools-> Options -> Advance -> Network -> "The following websites are allowed to store data for offline use" dialog. Remove the entry for the router.
