Flash drive disconnects (68U)
What do you have the USB drive formatted as? Are you using amtm or other available scripts? Are you using a swap file?
2GB swap, Diversion and Skynet. It's a USB3 flash drive that's formatted with ext2. Would like to try another flash drive. Can I copy the content with sudo cp -ra?
Try it in another port first. But if it doesn't work there either, then it is probably the drive. Buy a different brand. :)
Thanks! Connected a 1TB Seagate disk to it. It has no external power, but have been stable for more than half a day now. :) Cloned the Sandisk Ultra USB3 that was failing with the command: sudo dd if=/dev/sde1 of=/dev/sdf1 bs=64K conv=noerror,sync
Getting a lot of
RT-AC68U-AEE0 kernel: EXT2-fs (sda1): error: ext2_lookup: deleted inode referenced: 516104
On it.
Edit: There were several errors with the filesystem, that fsck.ext2 fixed. Cloned it it again with fsarchiver.
