RT-AC86C 384.12_alpha1-g40c9e42009
Apologies if this has been covered, I looked but could not find a specific response.
I am using Smart Connect on this router but there is one device (and one only) that I wish to force onto the 5GHz band. I am aware I can define two separate SSIDs and connect FROM the device to the 5GHz one and I believe that I could tweak Smart Connect Rules (although it might sometimes connect and sometimes not?) but I really just want to force one WiFi adpater onto a specific band based on a simpler method.
I guess I could also use the Wireless MAC Filter for that one device's MAC with an accept / reject rule? I tried it but it did not work. For this method, if I put in a filter for "Reject"ing that MAC on the 2.4GHz band, will it then still connect on 5GHz, or will the MAC address filter apply to ANY subsequent Wifi connections and refuse all connections? Or do I ALSO need to Accept the 5GHz Wifi (with 2.4GHz rejected)?
Lastly, as I have the device (and 20-odd others from all the kids gizmos) reserved via DHCP to an IP Address anwyay, I was wondering of it is possible to connect to a defined band by IP Address only?
TIA,
k.
TIA,
k.
