Force nvram settings after reboot
StavrosWTF
So I have been having trouble using my router's Smart Connect because of region problems (bought US router in Europe and my router automatically uses 149+ control channel which is not allowed here so my 5GHz isn't detected at all). So I guess the only fix for this is changing nvram (by editing settings.cfg file manually or using specific commands to set control channel) but it resets every time I reboot the router. Is there a way I can restore the edited settings.cfg or do some commands after it reboots?
