Forgot Username on Merlin 386.2_2
username0475
So when I last updated Merlin to 386.2_2, also took the opprtunity to change the admin username.
Of course, i didnt write it down either correctly or whatever.
Now I can't log-in to my AC86U router.
Is resetting back to factory the only way to get back in?
You have to reset it to back to factory defaults and set it up manually. Uploading saved configuration file after username change will lock you out again.
