Hello everyone.
When is it that someone would need to enable the Forward local domain queries to upstream DNS setting in the lan dhcp server tab?
What is a situation that this could be used for?
If you have a Windows Server, and need to configure your router to use it as its DNS instead of the ISP's DNS, so you can resolve your LAN domain.
ping 192.168.66.70
PING 192.168.66.70 (192.168.66.70): 56 data bytes
64 bytes from 192.168.66.70: icmp_seq=0 ttl=64 time=0.126 ms
ping onehost
ping: cannot resolve onehost: Unknown host
nslookup 192.168.66.70
*** Aucun enregistrement internal type for both IPv4 and IPv6 Addresses (A+AAAA) disponible pour 192.168.66.70
Serveur : resolver2.opendns.com
Address: 208.67.220.220
can't find 70.66.168.192.in-addr.arpa.: NXDOMAIN
My next question is then, can I reach my goal (using OpenDNS) with local names configured in the router?
Indeed, I should have started with my need:
I want to replace my default DNS Server (my ISP's).
This DNS server entry from DHCP section looked promising. I've set it up with OpenDNS IP but as soon as this is activated, my local names (manually configured in DHCP Server section) are not recognized anymore.
Thus my question on the forward option, as it seems to be forwarded even if it is set to "no".
I've reverted back to default and then tried the DNSFilter as you mentioned. Unfortunately results are exactly the same. As soon as activated local names are unknown.
It's normal then that you can no longer resolve local hostnames - your computers are no longer talking at all with your router for DNS duties, they go directly to the specified DNS.
leads to even more confusion."Forward local domain queries to upstream DNS = no"
For a printer I don't think it will make any difference. Standard practice would be to set it to the IP address of your local DNS server. Which your case would be the IP address of the router.Question on the above - So when I am setting up my wireless printer (which already has a static address), should I be setting the DNS to an OpenDNS/GoogleDNS address or to the address of my router?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
