foodmonkey
have a server box that has been cobbled together
v1
old on asrock mobo
lsi 3081e HBA controller
sff 8087 --> 4x sas drive breakout cable
installed RockStor and worked perfrectly
came across an old sas hot plug drive cage with backplane so in that went (dremel, drill, paint)
v2
same rig except
sff 8087 (36pin) to 8087 (36pin) from controller card to backplane (much tidier)
booted up and worked a treat.
the problem - there's always a problem
the hp backplane doesn't support the SGPIO sideband signals - it only has an I2C plug on it
and the lsi HBA card doesn't have an I2C plug - upshot of it all - the leds in the drive cage flicker on powerup (backplane self-test obviously) but no other blinking during activity.
have purchased a usb to i2c breakout circuit board that has a Python toolkit for it
SOOOO - question is - does anyone know or have access to any doco on what the i2c command stream looks like from an HP Proliant 330 G6 server mobo to it's i2c SAS backplane?
if i had the command (byte stream) for this - i could code something up in python to allow integration into some current NAS platforms
i know it's a fairly eclectic and specific request but surely there's gotta be an HP engineer out there who knows or knows where the doco is.
v1
old on asrock mobo
v2
same rig except
