May be useful to someone for parts so offering for free (cost of postage) my Netgear SRXN3205.
Some background on the issue with the device:
After following Netgear's firmware install to the letter the device no longer allows you to login to the web console using the admin login. The guest login works fine (but you can't change settings with this). Both logins work fine if you use the CLI to configure the router (only limited settings can be changed from the CLI from what I can work out). I have fully reset the device which has made no difference. Netgear support were about as helpful as a chocolate fireguard so I gave up with it.
Includes:
* Antenna's (x3)
* UK power supply (x1)
* Resource CD (x1)
* VPN access software CD's (x2)
All I ask is that the postage cost is covered. Preferrably ship to UK address, but if you are outaside the UK and willing to pay the postage cost I will arrange shipment.
Includes:
* Antenna's (x3)
* Resource CD (x1)
