freeradius3 : (TLS) Failed loading legacy provider
dony71
admin@RT-AC68U-A938:/tmp/mnt/EXT4/entware/etc/freeradius3/certs# radiusd -XX
Fri Mar 29 01:06:21 2024 : Debug: Server was built with:
Fri Mar 29 01:06:21 2024 : Debug:   accounting               : yes
Fri Mar 29 01:06:21 2024 : Debug:   authentication           : yes
Fri Mar 29 01:06:21 2024 : Debug:   ascend-binary-attributes : yes
Fri Mar 29 01:06:21 2024 : Debug:   coa                      : yes
Fri Mar 29 01:06:21 2024 : Debug:   control-socket           : yes
Fri Mar 29 01:06:21 2024 : Debug:   detail                   : yes
Fri Mar 29 01:06:21 2024 : Debug:   dhcp                     : yes
Fri Mar 29 01:06:21 2024 : Debug:   dynamic-clients          : yes
Fri Mar 29 01:06:21 2024 : Debug:   osfc2                    : no
Fri Mar 29 01:06:21 2024 : Debug:   proxy                    : yes
Fri Mar 29 01:06:21 2024 : Debug:   regex-pcre               : no
Fri Mar 29 01:06:21 2024 : Debug:   regex-posix              : yes
Fri Mar 29 01:06:21 2024 : Debug:   regex-posix-extended     : yes
Fri Mar 29 01:06:21 2024 : Debug:   session-management       : yes
Fri Mar 29 01:06:21 2024 : Debug:   stats                    : yes
Fri Mar 29 01:06:21 2024 : Debug:   systemd                  : no
Fri Mar 29 01:06:21 2024 : Debug:   tcp                      : yes
Fri Mar 29 01:06:21 2024 : Debug:   threads                  : yes
Fri Mar 29 01:06:21 2024 : Debug:   tls                      : yes
Fri Mar 29 01:06:21 2024 : Debug:   unlang                   : yes
Fri Mar 29 01:06:21 2024 : Debug:   vmps                     : yes
Fri Mar 29 01:06:21 2024 : Debug:   developer                : no
Fri Mar 29 01:06:21 2024 : Debug: Server core libs:
Fri Mar 29 01:06:21 2024 : Debug:   freeradius-server        : 3.0.26
Fri Mar 29 01:06:21 2024 : Debug:   talloc                   : 2.3.*
Fri Mar 29 01:06:21 2024 : Debug:   ssl                      : 3.0.0m dev
Fri Mar 29 01:06:21 2024 : Debug: Endianness:
Fri Mar 29 01:06:21 2024 : Debug:   little
Fri Mar 29 01:06:21 2024 : Debug: Compilation flags:
Fri Mar 29 01:06:21 2024 : Debug:   cppflags : -isystem /data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/include/ -I/data/entware-armv7-2.6/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/usr/include -I/data/entware-armv7-2.6/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/include -I/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libiconv-full/include -I/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libintl-full/include -I/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/include
Fri Mar 29 01:06:21 2024 : Debug:   cflags   : -I. -Isrc -include src/freeradius-devel/autoconf.h -include src/freeradius-devel/build.h -include src/freeradius-devel/features.h -include src/freeradius-devel/radpaths.h -fno-strict-aliasing -Wno-date-time -O2 -pipe -mtune=cortex-a9 -fno-caller-saves -fhonour-copts -mfloat-abi=soft -I/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libiconv-full/include -I/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libintl-full/include -DHAVE_OPENSSL_RAND_H -Wall -std=c99 -D_GNU_SOURCE -D_REENTRANT -D_POSIX_PTHREAD_SEMANTICS -DOPENSSL_NO_KRB5 -DNDEBUG -DIS_MODULE=1
Fri Mar 29 01:06:21 2024 : Debug:   ldflags  :  -L/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib -Wl,-rpath,/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib -Wl,--dynamic-linker=/opt/lib/ld-linux.so.3 -Wl,-rpath=/opt/lib -L/data/entware-armv7-2.6/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/usr/lib -L/data/entware-armv7-2.6/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/lib -fuse-ld=bfd -L/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libiconv-full/lib -Wl,-rpath-link=/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libiconv-full/lib -L/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libintl-full/lib -Wl,-rpath-link=/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib/libintl-full/lib -L/data/entware-armv7-2.6/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib
Fri Mar 29 01:06:21 2024 : Debug:   libs     : -lcrypto -lssl -ltalloc -lcap -lnsl -lresolv -ldl -lpthread -latomic -lcrypto -lssl -lcrypto -lssl -lcrypto -lssl -lcrypto -lssl -lreadline
Fri Mar 29 01:06:21 2024 : Info: FreeRADIUS Version 3.0.26
Fri Mar 29 01:06:21 2024 : Info: Copyright (C) 1999-2021 The FreeRADIUS server project and contributors
Fri Mar 29 01:06:21 2024 : Info: There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
Fri Mar 29 01:06:21 2024 : Info: PARTICULAR PURPOSE
Fri Mar 29 01:06:21 2024 : Info: You may redistribute copies of FreeRADIUS under the terms of the
Fri Mar 29 01:06:21 2024 : Info: GNU General Public License
Fri Mar 29 01:06:21 2024 : Info: For more information about these matters, see the file named COPYRIGHT
Fri Mar 29 01:06:21 2024 : Error: (TLS) Failed loading legacy provider
It's a radius server, ssl library mismatch...
It can be fixed, but this crosses into the OpenSSL land, and replacing OpenSSL in AsusWRT can be problematic...
