Frequent Disconnects
jplw
I have an RT-AX300 Router and RT-AX82U AiMesh node. I have a device (a Harmony Hub) with MAC address 00:04:20:F3:7E:09 connected to it from 6 feet away. The hub is bound to the 82U. It disconnects several times per day, with messages like this in the log (these messages are after a system reboot about an hour ago):
Dec 17 09:59:15 wlceventd: wlceventd_proc_event(685): eth2: Auth 00:04:20:F3:7E:09, status: Successful (0), rssi:0
Dec 17 09:59:15 wlceventd: wlceventd_proc_event(722): eth2: Assoc 00:04:20:F3:7E:09, status: Successful (0), rssi:-89
Dec 17 09:59:48 roamast: eth2: sta-ap-band-bind deauth [00:04:20:f3:7e:09]
Dec 17 09:59:48 roamast: eth2: remove client [00:04:20:f3:7e:09] from monitor list
Dec 17 09:59:49 wlceventd: wlceventd_proc_event(645): eth2: Deauth_ind 00:04:20:F3:7E:09, status: 0, reason: Previous authentication no longer valid (2), rssi:-86
Dec 17 09:59:49 wlceventd: wlceventd_proc_event(645): eth2: Deauth_ind 00:04:20:F3:7E:09, status: 0, reason: Disassociated due to inactivity (4), rssi:-86
Any ideas what the problem could be?
Thanks, but I wonder why it changes? It just sits there--untouched--and then disconects and reconnects.
According to logs this device is somewhere around the edges of usable signal area. What is blocking the signal - I don't know.
