from Tomato to Merlin
simonex
I'm using ac56u router with tomato by shibby .
I would like flash Merlin firmware , through recovery mode ?
Is there a specific procedure to be followed ?
There is a version of merlin fw to be installed before to other or proceed with the last version RT-AC56U_378.55_0 ?
thanks
You don't need to use the recovery tool when flashing from Tomato. You may use Tomato's firmware upgrade page. Did it just this weekend.
Have gone back and forth a couple times. Make sure to do a factory reset after you switch. You will have to reconfig by hand once you are up and running on Merlin FW. You can't restore a shibby config file into Merlin.
