You could start by looking in the System Log and the ftp log (if available).
Also what does the FTP Client say in the protocoll or log?
System log on the router does not have anything about ftp server.
FTP client says "timeout".
I experimented with this little more; this problem happens only when there's more than one simultaneous transfer. Here's the log from the client (actually two intermixed logs of two simultaneous sessions transferring two files). Note that 98,435,194 bytes and 94,372,984 bytes are the exact sizes of the files, so both have timed out after they have been transferred. As I said, I tried different ftp clients, so it does not seem to be client's fault.
Status: Connection established, waiting for welcome message...
Response: 220 Welcome to ASUS RT-N66U FTP service.
Command: USER anastasia
Response: 331 Please specify the password.
Command: PASS *******
Response: 230 Login successful.
Command: OPTS UTF8 ON
Response: 200 Always in UTF8 mode.
Status: Connected
Status: Starting download of /STORAGE/ftp/capture2.avi
Command: CWD /STORAGE/ftp
Status: Connected
Status: Starting download of /STORAGE/ftp/capture1.avi
Response: 250 Directory successfully changed.
Command: TYPE I
Command: TYPE I
Response: 200 Switching to Binary mode.
Command: PASV
Command: PASV
Response: 227 Entering Passive Mode (76,193,185,147,39,38)
Command: RETR capture2.avi
Response: 227 Entering Passive Mode (76,193,185,147,24,25)
Command: RETR capture1.avi
Response: 150 Opening BINARY mode data connection for /tmp/mnt/STORAGE/ftp/capture2.avi (98435194 bytes).
Response: 150 Opening BINARY mode data connection for /tmp/mnt/STORAGE/ftp/capture1.avi (94372984 bytes).
Error: Connection timed out
Error: File transfer failed after transferring 98,435,194 bytes in 2388 seconds
Status: Resolving address of (...)
Status: Connecting to 76.193.185.147:21...
Status: Connected
Command: TYPE I
Command: PASV
Response: 227 Entering Passive Mode (76,193,185,147,57,35)
Command: REST 98435194
Response: 350 Restart position accepted (98435194).
Response: 226 File send OK.
Status: File transfer successful, transferred 0 bytes in 1 second
Error: File transfer failed after transferring 94,372,984 bytes in 2409 seconds
Command: PASV
Response: 227 Entering Passive Mode (76,193,185,147,231,14)
Command: REST 94372984
Response: 350 Restart position accepted (94372984).
Status: Retrieving directory listing...
Command: PASV
Response: 227 Entering Passive Mode (76,193,185,147,100,53)
Command: REST 0
Response: 350 Restart position accepted (0).
Command: LIST
Response: 150 Here comes the directory listing.
Response: 226 Directory send OK.
Status: Directory listing successful
Status: Disconnected from server
Any reason you are not using 374.40 final?
Thanks for poiting that out. By now I have updated already to 374.40 release; no change.
