CaptainSTX
Part of the Furniture
For most home users what are the advantages of running a local VPN server for inbound connections to access files vs. FTP?
Other than the data being transmitted being encrypted I don't see many assuming that you properly secure your FTP server.
VPN puts a heavy load on your router and slows down your connection.
While you can easily connect using PCs running an OpenVPN client, many mobile devices can't so you need to use PPTP which isn't that secure.
I use an FTP server to make all my personal photos available on line if I want to show them to someone using a phone, tablet, PC etc. They quickly download using even a slow connection and/or a slow device.
The files are all on an USB thumb drives attached to a router double NATed behind my primary router.
Port 21 is only forwarded from my primary to secondary router during the hours 8 AM - 6 PM local time. The USB drives are connected to my N66U ASUS router
I use a secure fifteen character password. The Tomato software is set to only allow three connection attempts every ninety seconds.
All files and folders are set to be read only. One of thumb drives has a mechanical switch that makes the drive read only.
All the photos are backed up elsewhere and off line.
The FTP server is set to only allow a single connection at any one time.
In looking at the router's logs for the past several months I don't show a single attempt to hack into my FTP connected drives.
In summary I am able to quickly download files using readily available FTP clients on all type of devices. What's the downside other than the files are not encrypted? I would be concerned if I was downloading the formula for Coke or McDonalds secrete sauce receipe but I use it to show photos and on occasion an article I have clipped.
