vnStat Full removal and reinstall?
croldan72
I haven't been getting updates from vnStat in over a month. I went to go check vnStat through AMTM and it hangs when just trying to get to the menu. So I can't use AMTM to uninstall/ reinstall. So I tried the full UI-enabled install script (/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/de-vnull/vnstat-on-merlin/main/dn-vnstat.sh" -o "/jffs/scripts/dn-vnstat" && chmod 0755 /jffs/scripts/dn-vnstat && /jffs/scripts/dn-vnstat install) and I get a "Segmentation fault" message. Can anyone recommend how to correct?
