I wanted to share if anyone who has been using AImesh and enabled guest network 1 slot and set it to be enabled in their guest nodes might have network issues.
I have been basically having this issue for 2 years where random clients sometimes just wont be able to be pinged. I just assumed that it was my noisey envoriment or faulty devices.
I eventually looked through all the threads related to why some clients can not be pinged and stumbled upon someone who had the same issue and their solution which was tested was to disable guestnetwork slot 1 and sharing to aimesh nodes was the issue.
I have confirmed it as well.
TL'DR
If you use AImesh and have a guest network on Slot 1 shared to all the nodes, you might be having the issue where clients can not be pinged. The only remedy is to put the guest network on another slot and router only.
TL'DR
