Can anyone confirm that the RT-AX88 can handle full Gbit throughput with fq_codel QoS active? My current RT-AC87U (dual core) can't, since the HW accel. gets disabled. Getting capped at around 5-600 Mbit or so, with 100% router CPU usage. The RT-AX88 has higher clock frequencies and a newer architecture though, so it just might. Would love a confirmation from someone.You can look for the newer RT-AX88 with Merlin support or the GT-AC5300 is quiet good since a lot of bugs have been fixed
Thanks, nice info. I'd prefer not to go the x86 route due to the cost and power usage, but if I have to I might. Just want to see if anyone know of a dedicated HW solution first.
Thanks, I'll check that script out! No, I can just use QoS with my current RT-AC87U too of course, but I don't like the bandwidth hit.See FreshJR's take on QoS on Asus routers and his great script that makes big and obvious improvements, even at default levels.
FreshJR doesn't recommend using QoS with 1Gbps connections currently with Asus routers but running a Gbps network with the RT-AC86U there have been no issues for me for latency, even with using AiProtection and all the scripts in my signature too.
No of course I don't NEED it. =) This is a pure luxury problem and an excuse for buying new stuff. I could just bandwidth cap my server to 800 Mbit and not use QoS. But, speed is crucial for RSS torrenting and ratio build, cause by the time your DL is completed there has to be someone left to seed to, and the other guys are on seed boxes in the same server hall with LAN speeds.I doubt 1 gig really needs QoS unless you are a business.
One could argue the closer the link speed across interfaces, the less additional QoS, queuing and/or shaping disciplines are required at that hop. Still, even on multi-hundred MB/s+ WAN links NAT'ing to gigabit LANs, I've seen plenty of times where activating an AQM beyond pfifo_fast does improve ping consistency and jitter. So flow efficiency does improve, almost universally, regardless of link speed. Rather, the question is whether the amount of added benefit is worth going out of your way to implement. In cases where WAN and LAN link speeds are closely matched (ie. both gigabit in this case), and you're also not running anything else that would require you to go to x86, I would say you could go without it, save your pennies, and stick with an ARM or MIPS box.[...]No of course I don't NEED it. =) This is a pure luxury problem and an excuse for buying new stuff. I could just bandwidth cap my server to 800 Mbit and not use QoS.[...]An easy solution would be to just let the PC have higher priority than the server, but I didn't manage to get that working very well with my current router, as it sets a hard limit on bandwidth on anything with less than top priority.
Yes, not a 24/7 load.I don't think 1 server can keep a 1 gig internet connection busy. It would be too much data over time.
So far i have not seen any router at all with a 2.5G/5G/10GB WAN port, there is a SFP port on the Ubiquiti Edgerouter X SFP you can make this port to a WAN port for fiber like i have. But you need a SFP module and a fiber cable.
Welcome To SNBForums
