Geforce Now! AC68U QoS?
finnpolle
Is it possible to apply these settings in Adaptive QoS on a AC68U?
GeForce NOW Ports
Starting with the GeForce NOW (GFN) PC and Mac apps v1.13.2.5 or later, the GFN apps use fixed ports for streaming games. In order to further improve streaming quality when using GFN, we suggest using GFN optimized routers or engage your existing router QoS by adding GFN app ports to the active router’s QoS profile. Here are the ports to add:
  • 49003 – UDP Inbound AUDIO
  • 49004 – UDP Outbound AUDIO
  • 49005 – UDP Inbound VIDEO
  • 49006 – TCP/UDP Outbound/Inbound Remote Input
If you are not using a GFN certified routers, please consult with the technical support page for your router how to configure the router QoS engine to improve your gaming experience.
If your router QoS supports port based prioritization, you may consider creating custom router QoS rules based on the port information provided above.
No, Adaptive QoS does not allow to customize rules.
I added ports in qos_rulelist and it seems to work.
<Web Surf>>80>tcp>0~512>0<HTTPS>>443>tcp>0~512>0<File Transfer>>80>tcp>512~>3<File Transfer>>443>tcp>512~>3<Xbox Live>>88,3074>tcp/udp>>0<Geforce NOW 01>>49003>udp>>0<Geforce NOW 02>>49004>udp>>0<Geforce NOW 03>>49005>udp>>0<Geforce NOW 04>>49006>tcp/udp>>0
/jffs/nvram/qos_rulelist
That would apply only for Traditional QoS, not Adaptive QoS.
