Getting Traffic Monitor Values Programmatically
macdis
I'm wondering if it's possible to retrieve Traffic Monitor throughput data programmatically (MB/s, see screenshot).
I can retrieve the data via a series of curl calls, but is there is a simpler way to retrieve it?
My current method is ok, I guess, but clunky. Basically, it's as follows:
1. Get the login_authorization token (hashed username+password) via Chrome dev tools. This only has to be done once and can be reused until you change your username or password.
2. curl login.cgi, using the login_authorization token to get the asus_token session cookie.
3. curl update.cgi using the asus_token session cookie to retrieve the data. Since the data is cumulative and measured in bytes, this step has to be done twice to calculate a transfer rate in bytes/second. The retrieved data is of the following form, which indicates cumulative byte values in hex:
netdev = {
 'BRIDGE':{rx:0xb37d3bc3c0,tx:0x933c86706a}
,'INTERNET':{rx:0x58aea7d5e2,tx:0x75cae6fe6e}
,'WIRED':{rx:0xde923a8334,tx:0xbe071d1285}
,'WIRELESS0':{rx:0x1f4490,tx:0xd208abd}
,'WIRELESS1':{rx:0x1d46764,tx:0xd9824ce}
,'LACP1':{rx:0x38d8681136,tx:0x1cb1e05be1}
,'LACP2':{rx:0x905d616b46,tx:0x8ca6fe4c7e}
4. Logout via curl.
5. Do the math (to convert cumulative bytes to Mb/s or whatever).
(I basically adapted the above process from a sort of unrelated but interesting tutorial on a now dead website. Here's the wayback machine link, if anyone's interested.)
I don't think it matters much, but I have an RT-AX88U running 3004.388.8_4.
Thanks!
Assuming that eth0 is the WAN interface (it is, isn't it?), I am realizing that I can probably also do this via
ssh me@router 'cat /sys/class/net/eth0/statistics/rx_bytes'
ssh me@router 'cat /sys/class/net/eth0/statistics/tx_bytes'
Been asking same question to myself couple of days ago. Ended up trying the following with my gt-ax6000 3004.388.8_4 :
https://github.com/Vaskivskyi/asusrouter
AsusData.NETWORK returns the following structure:
{'wan': {'rx': 396035939110, 'tx': 111527332367, 'rx_speed': 0.0, 'tx_speed': 0.0}, 'wired': {'rx': 9806726476, 'tx': 60173605806, 'rx_speed': 0.0, 'tx_speed': 0.0}, 'bridge': {'rx': 108797187644, 'tx': 395545353415, 'rx_speed': 0.0, 'tx_speed': 0.0}, '2ghz': {'rx': 238424661, 'tx': 2586632521, 'rx_speed': 0.0, 'tx_speed': 0.0}, '5ghz': {'rx': 60846630938, 'tx': 360517350768, 'rx_speed': 0.0, 'tx_speed': 0.0}, 'usb': {'rx': 0, 'tx': 0, 'rx_speed': 0.0, 'tx_speed': 0.0}}
for some reason rx_speed/tx_spedd stay constantly at 0. Going to to play with throughput calculation based on total bytes of tx/rx. Additionally refresh rate of api is not what I expected or my python skills are not enough.
And a tool like Beszel provides an at-a-glance monitoring solution for a bunch of stuff, including send/receive speeds, accessible through a web UI or Pocketbase web API, email notifications, and blah blah blah. Might be useful in some situations. Has to be installed manually to jffs and started via the services-start script. The WAN interface can be selected at startup.
If you're looking for router totals (not individual interfaces), vnStat does that (incorporated into vnStat-on-Merlin: https://www.snbforums.com/goto/post?id=677569). The underlying program vnStat has several options, including -l (dash el) to capture live usage.
