Getting WAN IP in a script
david3
I used to use Tomato firmware, and I have scripts that use the WAN IP.
I could get it like this:
#!/bin/sh
WANIP=$(nvram get wan_ipaddr)
echo $WANIP
Now I've updated my router (an Asus RT-N66U) to use Asuswrt-Merlin firmware, and I guess it doesn't work the same way, since the above code isn't giving me my WAN IP.
What's the best way to get the WAN IP for Asuswrt-Merlin?
The above does get an IP, but it's not my current IP (maybe an old one?)
Thanks.
Both wan_ipaddr and wan0_ipaddr work for me.
Edit: There's also wan1_ipaddr for dual WAN support.
The nvram command also works for me.
As an alternative though I just did this and it also works (assuming eth0 is your WAN port);
ifconfig eth0 | grep "inet addr" | sed -r 's/.*r:(.*) B.*/\1/'
Use wan0_ipaddr
wan_ipaddr is a gui only construct that reflects the address in effect the last time you accessed a page that needed the wan address.
Thanks, it looks like wan0_ipaddr is working.
#!/bin/sh
WANIP=$(nvram get wan0_ipaddr)
echo $WANIP
wan_ipaddr returns something different. Maybe the previous or an old WAN IP address.
I know this is an old thread but I have related question.
if I use this command to get the IP of my dual wan :
nvram get wan1_ipaddr
I get a the local I address of the the dual wan device not its public IP address. How can I get its public IP address?
Try:
nvram get wan1_realip_ip
