Jan 22 11:39:49 rc_service: cfg_server 3133:notify_rc stop_upgrade;start_webs_upgrade 1
[... steps ommited from log by OP...]
fw/rsa, Start
Jan 22 11:39:54 AUTO_UPGRADE: cfg_trigger=1
Jan 22 11:39:54 AUTO_UPGRADE: wget fw beta GT-AX6000_9006_102_4856-g8178ee0_un.zip
Jan 22 11:39:56 AUTO_UPGRADE: exit code: 0
Jan 22 11:39:56 AUTO_UPGRADE: wget fw beta GT-AX6000_9006_102_4856-g8178ee0_rsa3.zip
Jan 22 11:39:56 AUTO_UPGRADE: mv trx OK
Jan 22 11:40:00 AUTO_UPGRADE: fw check OK
Jan 22 11:40:00 AUTO_UPGRADE: To download fw/rsa, End
Jan 22 11:40:00 rc_service: rc 5199:notify_rc stop_logger
May 5 01:05:16 kernel: klogd started: BusyBox v1.24.1 (2023-05-07 09:39:15 CST)
May 5 01:05:16 kernel: Linux version 4.19.183 (gitserv_asus@bpza001bud) (gcc version 9.2.0 (Buildroot 2019.11.1)) #1 SMP PREEMPT Sun May 7 09:41:23 CST 2023
May 5 01:05:16 kernel: random: get_random_bytes called from start_kernel+0x9c/0x454 with crng_init=0
May 5 01:05:16 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe console=ttyAMA0,115200 earlycon rootwait mtdparts=brcmnand.0:2097152(loader),264241152@2097152(image),524288@266338304(crashlog) root=/dev/ubiblock0_4 ubi.mtd=image ubi.block=0,4 rootfstype=squashfs cma=0M
May 5 01:05:16 kernel: mtusize 1500
May 5 01:05:16 kernel: CCI hardware cache coherency enabled
May 5 01:05:16 kernel: bootloader version U-Boot 2019.07 (May 07 2023 - 11:38:54 +0800), Build: 5.04L.0
May 5 01:05:16 kernel: inMemNvramData.szBoardId GTAX6000_50991
May 5 01:05:16 kernel: size of sk_buff 512
May 5 01:05:16 kernel: offset of cb in sk_buff 368
May 5 01:05:16 kernel: PMC driver initcall
May 5 01:05:16 kernel: PMC driver scanning DT
May 5 01:05:16 kernel: pmc match PMC brcm,bca-pmc-3-2
May 5 01:05:16 kernel: Remapping PMC IO memories...
May 5 01:05:16 kernel: phys virt size
May 5 01:05:16 kernel: 0x00000000ffb01018 0xffffff8008db8018 0x00005080
May 5 01:05:16 kernel: 0x00000000ffb20000 0xffffff800809e000 0x00000240
May 5 01:05:16 kernel: 0x00000000ffb00400 0xffffff80080bc400 0x000005d0
May 5 01:05:16 kernel: 0x00000000ffb80000 0xffffff80080be000 0x00001000
May 5 01:05:16 kernel: pmc_init
MC using DQM mode
May 5 01:05:16 kernel: Powering on XRDP core...
May 5 01:05:16 kernel: Toggle reset of XRDP core...
May 5 01:05:16 kernel: map_hw_timer_interrupt,162: interrupt_id 68
May 5 01:05:16 kernel: map_hw_timer_interrupt,162: interrupt_id 69
May 5 01:05:16 kernel: map_hw_timer_interrupt,162: interrupt_id 70
May 5 01:05:16 kernel: map_hw_timer_interrupt,162: interrupt_id 71
May 5 01:05:16 kernel: Broadcom GBPM v0.1 initialized
May 5 01:05:16 kernel: Broadcom IQoS v1.0 initialized
May 5 01:05:16 kernel: Broadcom Logger v0.1
May 5 01:05:16 kernel: /dev/bcmnet Char device registered
May 5 01:05:16 kernel: skb_free_task created successfully with start budget 256
May 5 01:05:16 kernel: ^[[0;34mBLOG v3.0 Initialized^[[0m
May 5 01:05:16 kernel: BLOG Rule v1.0 Initialized
May 5 01:05:16 kernel: Skip Legacy Led init
May 5 01:05:16 kernel: Initialise system trusted keyrings
May 5 01:05:16 kernel: Key type asymmetric registered
May 5 01:05:16 kernel: Asymmetric key parser 'x509' registered
May 5 01:05:16 kernel: 3 cmdlinepart partitions found on MTD device brcmnand.0
May 5 01:05:16 kernel: Creating 3 MTD partitions on "brcmnand.0":
May 5 01:05:16 kernel: 0x000000000000-0x000000200000 : "loader"
May 5 01:05:16 kernel: 0x000000200000-0x00000fe00000 : "image"
May 5 01:05:16 kernel: 0x00000fe00000-0x00000fe80000 : "crashlog"
May 5 01:05:16 kernel: bcm63xx-hsspi ff801000.spi: spi driver using polling mode
May 5 01:05:16 kernel: brcmboard registered
May 5 01:05:16 kernel: brcmboard: brcm_board_init entry
May 5 01:05:16 kernel: Last RESET due to Unknown
May 5 01:05:16 kernel: RESET reason: 0x00000000
May 5 01:05:16 kernel: DYING GASP IRQ Initialized and Enabled
May 5 01:05:16 kernel: bcm_i2c: Error in loading module
May 5 01:05:16 kernel: Bridge Broadcom hooks registered
May 5 01:05:16 kernel: Loading compiled-in X.509 certificates
May 5 01:05:16 kernel: ubi0: attaching mtd2
May 5 01:05:16 kernel: ubi0: scanning is finished
May 5 01:05:16 kernel: ubi0 warning: ubi_calculate_reserved: number of bad PEBs (441) is above the expected limit (40), not reserving any PEBs for bad PEB handling, will use available PEBs (if any)
May 5 01:05:16 kernel: ubi0: attached mtd2 (name "image", size 252 MiB)
May 5 01:05:16 kernel: ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
May 5 01:05:16 kernel: ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
May 5 01:05:16 kernel: ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
May 5 01:05:16 kernel: ubi0: good PEBs: 1575, bad PEBs: 441, corrupted PEBs: 0
May 5 01:05:16 kernel: ubi0: user volume: 8, internal volumes: 1, max. volumes count: 128
May 5 01:05:16 kernel: ubi0: max/mean erase counter: 2325/552, WL threshold: 4096, image sequence number: 1616815245
May 5 01:05:16 kernel: ubi0: available PEBs: 0, total reserved PEBs: 1575, PEBs reserved for bad PEB handling: 0
May 5 01:05:16 kernel: ubi0: background thread "ubi_bgt0d" started, PID 118
May 5 01:05:16 kernel: Registered phy device: EGPHY:0x1
May 5 01:05:16 kernel: Registered phy device: EGPHY:0x2
May 5 01:05:16 kernel: Registered phy device: EGPHY:0x3
May 5 01:05:16 kernel: Registered phy device: EGPHY:0x4
May 5 01:05:16 kernel: Registered phy device: EXT3:0x11
May 5 01:05:16 kernel: Registered phy device: 10GAE:0x6
May 5 01:05:16 kernel: Registered phy device: EXT3:0x13
May 5 01:05:16 kernel: Registered phy device: 10GAE:0x7
May 5 01:05:16 kernel: UBIFS (ubi0:10): background thread "ubifs_bgt0_10" started, PID 213
May 5 01:05:16 kernel: UBIFS (ubi0:10): UBIFS: mounted UBI device 0, volume 10, name "data"
May 5 01:05:16 kernel: UBIFS (ubi0:10): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 01:05:16 kernel: UBIFS (ubi0:10): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs)
May 5 01:05:16 kernel: UBIFS (ubi0:10): reserved for root: 935592 bytes (913 KiB)
May 5 01:05:16 kernel: UBIFS (ubi0:10): media format: w5/r0 (latest is w5/r0), UUID D5A2EBE6-DC7C-4736-A60B-299AE0DA05AB, small LPT model
May 5 01:05:16 kernel: UBIFS (ubi0:11): background thread "ubifs_bgt0_11" started, PID 229
May 5 01:05:16 kernel: UBIFS (ubi0:11): UBIFS: mounted UBI device 0, volume 11, name "defaults"
May 5 01:05:16 kernel: UBIFS (ubi0:11): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 01:05:16 kernel: UBIFS (ubi0:11): FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
May 5 01:05:16 kernel: UBIFS (ubi0:11): reserved for root: 341850 bytes (333 KiB)
May 5 01:05:16 kernel: UBIFS (ubi0:11): media format: w5/r0 (latest is w5/r0), UUID 0D352230-D8BF-4434-A535-1FAAA80C06EE, small LPT model
May 5 01:05:16 kernel: UBIFS (ubi0:13): background thread "ubifs_bgt0_13" started, PID 259
May 5 01:05:16 kernel: UBIFS (ubi0:13): UBIFS: mounted UBI device 0, volume 13, name "jffs2"
May 5 01:05:16 kernel: UBIFS (ubi0:13): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 01:05:16 kernel: UBIFS (ubi0:13): FS size: 51171328 bytes (48 MiB, 403 LEBs), journal size 2539520 bytes (2 MiB, 20 LEBs)
May 5 01:05:16 kernel: UBIFS (ubi0:13): reserved for root: 2416947 bytes (2360 KiB)
May 5 01:05:16 kernel: UBIFS (ubi0:13): media format: w5/r0 (latest is w5/r0), UUID A30C6B97-7077-4016-BC84-61944535C31A, small LPT model
May 5 01:05:16 kernel: wlcsm: module license 'Proprietary' taints kernel.
