GNP VLANs in AP mode
MDFDoom
I'm looking for some clarity. I have 2 ET12 and 1 AX88U Pro (They are all running the firmware which supports GNP).
Currently, one ET12 is the main router and the others are AiMesh nodes. I have an IoT VLAN (52) which works fine and propagates
via my managed switches etc.
I'm planning on adding a new Unifi Router into my network (Cloud Gateway Max), and turning all my Asus machines into APs with a wired backhaul.
It isn't fully clear to me, but in AP mode can the Asus APs still assign VLANs to specific SSIDs in GNP?
Not sure if anyone has a setup like this?
TIA!
3.0.0.6 = vlans
So long as you are running 3.0.0.6 everywhere, vlans will work even in AP mode. ET12 shows only "beta" 3.0.0.6 support so you may run into bugs.
