Going a bit crazy with some port forwarding issues on RT-AC68P (Tmobile flashed)
seanyb316
Currently running Merlin 384.4_2 on my RT-AC68P
Ive been trying to get my port forwarding working for the past three days with no luck. I had the same setup with my Fios actiontec and it worked with no issues.
For whatever reason i am not able to get port 80 forwarded on my router from an exterior connection. For whatever reason if i set up the fowarding rule i am able to use the no-ip hostname for access on any computer still on the same LAN
As for network topology i currently have my Fios ethernet connected to the RT-AC68P and the Fios Actiontec router is still on the network hopefully just propely configured as a MOCA adapter
Any help would be greatly appreciated let me know if i can provide any other information
