@claykin: It seems you made a mistake reading my other thread (or is it so badly written?), I have 100Mbits router and all testing is done on 2 PCs directly connected via 10G cat6 cable.
And yes, the NIC is baked to the motherboard. GIGABYTE GA-M68M-S2P it has Onboard Realtek RTL8211CL (10/100/1000Mbit).
Directly connected via what?
RTL8211CL? I can hardly find any info on that NIC. visit www.realtek.com.tw and see what you can find. I type that into Realtek's search tool and am presented with a login box. Weird to say the least.
Yes, but I was thinking just about the NICs, if they, given perfect conditions can negotiate at gigabit speeds.There are other factors that are not the NICs fault.
Thx for your answers, now let me first clear some things up.
@YeOldeStonecat: Yes, but I was thinking just about the NICs, if they, given perfect conditions can negotiate at gigabit speeds.
@claykin: Directly connected via a network cable (1.NIC<cable>2.NIC), nothing in between.
Yes, I would be connecting 1Gbits, I just got 10G cables so I can safely say it's not the cable's fault.
All drivers are up to date.
I'm going to order new NICs monday.
@claykin: This is your third post where you don't understand what I'm saying. Since others can understand me, it seems you are the problem. And don't Just quote my whole post and add a at the end. If you don't understand something, explain what is unclear and I'll be happy to clear it out for you.
Welcome To SNBForums
