GPL Good News
bluepoint
GPL for RT-Ac66U .726 is in the Asus site now, soon RT-N66u will. That's good news we might see Merlin's magic based on this release in a week or two hopefully.;)
ASUS RT-AC66U Firmware Version 3.0.0.4.374.726
This version add many new features, please press the reset button more than 5 seconds to reset the RT-AC66U after firmware upgraded to prevent unexpected problem.
AiCloud 2.0 released
1.All new web interface
2. Support video subtitles (.srt format) For better video compatibility, windows user need to update VLC to v2.0.8 or later
3. File/ folder can be shared to Facebook(router must have public IP)
4. Supported mobile version web interface
5. Supported router to router sync
Please refer to video via:
http://www.youtube.com/watch?v=vG6BEjUrzfc&feature=share&list=UUlSsNTCjMEGj8Guo_NmiMWA
6. Fixed smartsync related issues.
Added:
1. Support Router/ Repeater / Media bridge/ AP mode
2. Dual WAN (in WAN -> Dual WAN)
Fixed:
1. Fixed HK ISP DHCP connection issue.
2. Fixed USB application update related issues.
is that GPL is newer than RT-AC56U latest official published FW 3.0.0.4.374.134?
Check Merlin's posts, pretty sure he has mentioned a few times that the different h/w now has uncorrelated and non-chronological rev #s. I can't find it at my fingertips, but he put up a good list the other day showing which h/w and which rev things are on.
You can usually safely rely on the release date from Asus to determine what is newer. So yes, N66 720 is newer than AC56 134 (not a lot of changes however, the two are fairly close), which is newer than N66 257.
Can't extract GPL_RT-AC66U_3.0.0.4.374.726-g10636ee.tgz. It says 'file is corrupt' :( I tried to redownload it 3 times... :( :(
That file is corrupted on Asus's server.
So, they actually didn't make 374.726 available :( A corrupted file is equal to no file at all. :(
I was able to recover most of that archive using gzrecover and cpio. It's almost virtually identical to the 720 release for the N66, minus a few webui pages, and some minor things here and there.
The wireless driver blobs are readable in that first half of the archive, and the rest can easily be reused from the N66U GPL or from the binary FW itself.
That sounds good. :) However, I hope ASUS will replace this corrupted file. It's much easier to compare two original source trees.
They will. It's currently a holiday in Taiwan, so it can take a few days however.
