[Solved workaround] grive2 compile ipk entware-ng armv7
amplatfus
Hello,
Could you please help me with a compile for grive2 file in order to include the changes available on Github, here https://github.com/Entware/rtndev/tree/master/grive2 Makefile and 500_oath.patch
I mention that I have entware-ng armv7.
Thank you so much!
Hello,
Thank you so much!
Find a workaround:
I updated the Entware-ng to Entware by entering 2 times
opkg update; opkg upgrade
I entered first:
grive -a --id 123-xyz.apps.googleusercontent.com --secret DE6XYZ
And after, every time I want to sync:
grive --id 123-xyz.apps.googleusercontent.com --secret DE6XYZ
And is working. Hope this helps!
All the best!
Sources:
https://github.com/Entware/Entware/issues/187#issuecomment-446946669
https://github.com/vitalif/grive2/pull/242#issuecomment-445212947
