Groundhog Day for RT-AC68U
RMerlin
Asuswrt-Merlin dev
Staff member
Howdy folks,
I'd like to have RT-AC68U owners who had the reboot issues try this early test build of 374.41-alpha4:
http://www.mediafire.com/download/4x6avc1668vnzl4/RT-AC68U_3.0.0.4_374.41_alpha4.zip
I mostly wish to confirm that I properly carried over Asus's fix from 374_4887 in it.
Note that this build has received very limited testing (it's been running on my main router for about 6-8 hours), and is far from a finalized 374.41 build.
Please test it out over the weekend, and confirm whether reboot issues are still gone.
Thanks!
Begin testing this Alpha4. Use old nvram parameters.
System Log - Active Connections: Refresh shows nothing.
Also confirming this after a factory reset, besides that been running fine the last few hours.
I also noticed Nat acceleration's options have changed (back) to Level 1 CTF / Level 2 CTF. Any news on this or is it still a useless setting as it was removed a few versions back
minor error
In file Advanced_VPN_Content.asp, one line broken:
	<th><#vpn_export_ovpnfile#></th>
	<td>
	<div id="export_div">
	<input id="exportToLocal" class="button_gen" type="button" value="<#btn_Expor
t#>" />
I do expect various webui issues, since I haven't validated the 4887 code merge yet. Merging new webui code from Asus's GPL is always the worst part of a new GPL merge...
Asus implemented some security validation in the httpd backend, I haven't integrated my own code into these new validations yet.
Wireless -> Professional tab
Roaming assistant RSSI lower than XXX will not allow a negative number. Used to specify this in -db... not sure if it's a UI bug or now the RSSI needs to be a positive number and just understood that it's a -db?
Thanks for the release! Quick and stable so far ;)
Working great for me!
Howdy folks,
Thanks!
I consider myself a nubee. I still enjoy trying new things. This is working great no reboots in the last hour.
cdc_ncm is included...;):D
login as: admin
admin@192.168.1.1's password:
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Fri Apr  4 06:00:27 UTC 2014
admin@RT-AC68U:/tmp/home/root# modprobe cdc_ncm
admin@RT-AC68U:/tmp/home/root# dmesg
usbcore: registered new interface driver usblp
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
cdc_ncm: 04-Aug-2011
usbcore: registered new interface driver cdc_ncm
admin@RT-AC68U:/tmp/home/root# lsmod | grep cdc_ether
cdc_ether               3224  1 rndis_host
usbnet                 12057  4 cdc_ncm,rndis_host,cdc_ether,asix
usbcore               108178 14 option,usb_wwan,usbserial,cdc_ncm,rndis_host,cdc_ether,asix,usbnet,usblp,ohci_hcd,ehci_hcd,xhci_hcd,usb_storage
admin@RT-AC68U:/tmp/home/root# lsmod | grep cdc_ncm
cdc_ncm                 7026  0
But E3276 seems to use cdc_ether.... howto swith??
Is there any special meaning to Groundhog day ??
Probably a reference to the movie Groundhog Day. Where bill Murray kept waking up on Groundhog Day over and over. Sort of like rebooting.
LOL ok that movie was funny. But what about Bob was better. Thanks !! :D
Ok I have been groundhogged just flashed the 41alpha4 so far so good. I love the fact Merlin added the Comcast neighbor over flow issue into this one. I do still see the flashing 5 ghz led but I am sure he did not get around to adding that fix in this alpha build.
Just that for the first time in this craptastic winter/spring we've had here, this week we finally got above the freezing point.
No reboot issues here (10hrs), but didn't have them earlier either, and WiFi is also OK
But still this USB/dualwan issue how come, it worked in erlier versions ???
WD USB3.0 disc must be in USB2.0 port otherwise my LTE modem in 3G+
don't work it's always in disconnected status
(Huawei E3270s-150 none hilinkmodel and WD My Book 3.0 3TB v2 "ntfs")
failover & failback works, and correct status: one "standby" not 2*connected as in asus 374.4887beta
thanks to Merlin
New bug introduced by Asus in 4887 - they now make validate_range() require positive values, which breaks the RSSI field validation.
thanks to Merlin
Ask that to Asus. I don't touch the Dual WAN code because it's too complex.
http://198.23.248.102/AC68U/RT-AC68U_3.0.0.4_374.41_alpha5.trx
+ - NEW: Merged with Asus's 374_4887 GPL. Notable changes:
+ * Fixed RT-AC68U random reboots
+ * More security fixes in the web server
+ * Improved Media server, SMB and FTP webui
+ - FIXED: Router crashing when more than around 30 static routes
+ were entered
+ - FIXED: webui would die for some users when accessing the VPN Server
+ config page and there were connected OpenVPN clients
+ - FIXED: Unable to enter a negative RSSI on the roaming assistant
+ section (Asus bug in 4887)
+ - FIXED: Couldn't obtain the list of active connections under
+ System Log -> Connections (Asus bug in 4887)
+ - FIXED: Added missing iptables-save on ARM platform (AC56, AC68)
+ - REMOVED: The Media server database location is no longer
+ configurable, as we've switched to Asus's new
+ automatic location selection.
Thx merlin... Going to flash this now
the astrill applet wont work with this,ill have to wait :(
Sent from my SM-N900T using Tapatalk
