Gt-Ac 5300 qos help
John DeLuca
Hello I was wondering if anyone could help me decipher what this log means.
Apr 16 02:59:46 kernel: ioctl_iqos_op_switch(1) fail!
Apr 16 02:59:49 kernel: ERR[__parse_app_rule:575] Failed to parse app rule catid value
Apr 16 02:59:49 kernel: ERR[parse_qos_conf:1038] Invalid config syntax at line 22.
Apr 16 02:59:49 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
Apr 16 02:59:49 kernel: ioctl_iqos_op_config() fail!
Apr 16 02:59:49 kernel: ERR[qos_start:3350] qos_conf is not already!
Apr 16 02:59:49 kernel: ioctl_iqos_op_switch(1) fail!
This is on in a constant loop, does that mean qos is failing? I just reset the router to factory settings and manually put my settings back in to the router. On another note, what qos settings are best, and for adaptive qos is the manual or automatic bandwidth setting best?
Manual and it's not failing, just some harmless errors I wouldn't worry about it too much.
