GT-AX 6000 upgrade
Epi
I recently faced a warranty case with GT AX 6000.
I am looking for a replacement. Features wise my old router was fine, it had it all.
Would you recommend some newer model? With similar features, great if a bit cheaper, but not mandatory.
I also don’t need the big range, as I’ve moved to a smaller apartment since originally buying gt ax 6000 for.
Replacement model is RT-BE88U. No 6Ghz like Gt-AX6000 but you will get upgraded SOC and dual 10G LAN and WAN ports. Longer firmware update support. Till Dec 2028.
That's an overkill. I'm not sure I need WiFi 7, also, paying 425 EUR for RT-BE88U while GT-AX6000 costs 220 EUR doesn't sound right.
Any models worth considering around 200 EUR budget?
