Use a computer connected directly to the router using Ethernet wire.Im try to update my GT-AX11000 to GT-AX11000_3004_388.8_0_ubi But after the reboot the firmware is still GT-AX11000_3004_388.7_0_ubi
What can I do about this?
I store always the firmware that's installed and download the new one. Compare filenames. I have the correct one. Will try different browserMake sure you download the correct fw for your device. Also try to update using a differnet web browser i.e. Firefox, Chrome or IE. Delete cache/cookies and try again.
Try a different web browser.
Try a different computer.
Temporarily disable any browser add-ons or extensions.
Temporarily disable any third party anti-malware, anti-virus or security software.
Temporarily disable any VPN software that may be running on the computer.
Double check you are downloading the correct firmware for your device.
https://sourceforge.net/projects/as.../Release/GT-AX11000_3004_388.8_0.zip/download
Anytime I have experienced issues flashing the next version of firmware it was because I had a mounted hard drive that refused to umount because a hung process was still running off the drive. Subsequent failure to umount the disk resulted in failure to flash new firmware. Also, I have seen a failure because the issue was firmware related, where something was not properly accounted for during the compile time of the firmware itself. With your case, its hard to say. I would recommend you unmount any storages, or swap files from the router, and also temporarily disable custom scripts to eliminate these two options as the problem child. Once you have done that, try flashing again.Thanks for the info. There is nothing changed in my household or my computer. System running for months and updated the FW several times in the past. Only that has been changed is my MacOS version on my iMac. So will try I different browser or even use my Macbook to see if this will help.
Welcome To SNBForums
