zombeeh8er
Hi all,
I'm having a strange problem with my GT-AX11000. There is no pattern to it and no indication of a problem in the log, at least, that I can see.
I attached a snippet of my syslog where the "problem" occurs.
Here's what I'm experiencing (on the daily):
- ALL 2.4ghz wifi clients (voice assistants, thermostat, etc) get deauthenticated, and cannot reconnect to the main router - BUT they can
reconnect to the two mesh routers I have in my network. But no internet access.
- No internet access on any other devices, but my cable modem is still online and the router thinks it still has a WAN connection
The router never recovers from this on its own. I always have to reboot it, and it works great after that for a random amount of time.
I posted here about 8 months ago with a similar problem however a firmware reflash and hard factory reset + jffs format fixed it for some time,
two or three months, before it had to be restarted because of a power outage... then this started happening again.
Doesn't matter what version of firmware I use, or how many times I hard factory reset the thing, it keeps having the same problem. I'm going to
reset it again and run a minimum config for a while and see if it helps, but in the meantime, any ideas?
