Libre.autonome
Hello all
I would like to share with you My Fan installation on the GT-AX11000.
please refer to : https://www.thingiverse.com/thing:5042131
After reviewed the initial temperature in the GT-AX11000 I decided to implement this solution.
Please note that this solution reduce the temperature than 80°C to around 50°C the internal CPU and reduce than 50°C to 40°C the internal WiFi controller.
For your information I used a FAN of 12 cm 12 V from Noctua. the 12V work in 5v from usb.
However the speed is less than specification and allow to reduce the noise while remain a a good cool efficiency.
Hoping this work help you!!!
