GT-AX11000 Pro potentially unexpected fatal signal 11 (3.0.0.6.102_34713)
ronan_zj
I just update my GT-AX11000 Pro to the latest 3.0.0.6.102_34713 today, and system log shows potentially unexpected fatal signal 11. I never saw this error message in 3.0.0.4 firmware, and I am not sure if this is just the new firmware bug?
my Router is in AP mode, so no other features are enabled in the Asus router.
Jun 5 07:45:02 kernel: potentially unexpected fatal signal 11.
Jun 5 07:45:02 kernel: CPU: 1 PID: 10802 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Jun 5 07:45:02 kernel: Hardware name: GTAX11000_PRO (DT)
Jun 5 07:45:02 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Jun 5 07:45:02 kernel: pc : 00000000f742a8e8
Jun 5 07:45:02 kernel: lr : 00000000f742a764
Jun 5 07:45:02 kernel: sp : 00000000ff9b80a0
Jun 5 07:45:02 kernel: x12: 00000000f7539c18
Jun 5 07:45:02 kernel: x11: 00000000ff9b85ac x10: 000000000023e044
Jun 5 07:45:02 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Jun 5 07:45:02 kernel: x7 : 0000000000000000 x6 : 00000000ff9b81e8
Jun 5 07:45:02 kernel: x5 : 0000000000000000 x4 : 00000000ff9b8be8
Jun 5 07:45:02 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Jun 5 07:45:02 kernel: x1 : 00000000f7539c18 x0 : 0000000000000000
You are already discussing this issue in the relevant firmware thread:
OE
OE
yea, I tried to delete this post, but I couldn't find the option to do it.
OE
Can this be installed over merlin or have to back up the settings ?
Flash over Merlin, factory reset with initialize and manually configure. Without doing a factory reset you could have issues.
Yes... read the Asuswrt-Merlin documentation for reverting:
Also, always review the firmware release notes first for any special instructions.
Save a firmware configuration to .cfg file for recovery only... recovery means restoring the same physical router to the same firmware version and its saved configuration.
OE
Did you ever find out the issue and how to fix it as I'm going through the same thing.
