GT-AX11000 route command or asus problem?
thecatman
Hello everyone!
Sorry if the question has been asked many times but I can't figure it out.
I have this router asus gt-ax11000 with latest merlin firmware 3004.388.8.2 (replacing the gt-ax6000 burned by the storm) and timhub ( provider TIM router) configured as a pure modem. They are connected in cascade and I want to reach the timhub interface. Before, everything worked and after I changed router and kept the same configuration, where possible, I can no longer reach the timhub login screen. For the rest the internet works.
So, timhub configuration:
fixed ip 192.168.10.1
dhcp no, nat no, upnp yes, wifi no, only connection to tim provider like a modem.
AX11000 (ip router 192.168.1.2)
wan connection pppoe
ip 192.168.10.2 (ip of the asus for connection of pppoe)
gw 192.168.10.1 (ip of the tim modem)
dns wan 192.168.10.1/8.8.8.8
in the lan settings of the ax11000, ip 192.168.1.2
route menu set like this 192.168.1.0/ 255.255.255.0/ 192.168.10.0/ LAN
and so, BEFORE, from firefox I accessed the tim modem interface.
Now it doesn't work anymore. What has changed if it worked until yesterday?
What secret menus or configurations does this ax11000 hide?
Thanks.
ping 192.168.10.2
Esecuzione di Ping 192.168.10.2 con 32 byte di dati:
Risposta da 192.168.10.2: byte=32 durata<1ms TTL=64
Risposta da 192.168.10.2: byte=32 durata=1ms TTL=64
ping 192.168.10.1
Esecuzione di Ping 192.168.10.1 con 32 byte di dati:
Richiesta scaduta.
Richiesta scaduta.
Richiesta scaduta.
Richiesta scaduta.
i don't know about tim hub , but the router modem supplied by my ISP I can no longer reach the modem/router interface once it was put in bridge mode
no, mine works normally as a pure modem with its public IP and manages the telephone part, the second router connects to the modem via ppoe and acquires another public IP. however everything works except that from the asus I can't see the modem while with the old router everything worked.
edit: I checked the wan settings of the tim hub but there are no settings as it is remotely managed. I only see ppp connection ok. I can only change the nat / upnp / dhcp / wifi / dmz / lan. if I use the old ac68u with the same current configuration I can access the modem.
